Construction d'un hélicoptère monoplace ultraléger.
"Documentation complète de construction en taille réelle d'un hélicoptère monoplace expérimental ultraléger. La construction est basée sur des cartes/plans existants."
EXPERIMENTAL HELICOPTER BUILD SERIES: (+ de 133 videos) => https://www.youtube.com/playlist?list=PLskozyWjbX0fyyVn9oDTycp0riXIy8obh&si=A8x8JE87A3_p-JRe
il y aura 3 compilations => https://www.youtube.com/playlist?list=PLskozyWjbX0e2aGL6j_aWlCFZbWD8HGjb&si=_AHgrzOW4__TnJE1
0:00:00 Intro
0:00:15 #1 Landing Gear Skids
0:22:20 #2 Main Frame Structure
0:35:28 #3 Pilot Flight Controls
0:54:43 #4 Main Rotor Head
1:10:06 #5 Custom Pilot Seat
1:18:52 #6 Main Gearbox Housing
1:30:45 #7 Tail Boom Mount
1:37:53 #8 Main Rotor Shaft
1:44:19 #9 Cockpit Instrument Panel
1:55:32 #11 Main Gearbox Assembly
2:07:44 #12 Main Gearbox Mount
2:16:31 #13 Main Rotor Control System
2:26:10 #14 Main Rotor Head Mount
2:35:07 #15 Basic Cabin Structure
2:41:43 #16 Rotax Engine Unboxing
2:47:40 #17 Rotax Engine Mount
2:57:19 #18 Rotax 582 UL Engine Components
3:02:57 #19 Exhaust System Mount
3:14:10 #20 Weight+ Balance Basics
3:19:22 #21 Twin Carburetor Mount
3:26:21 #22 Air Filter Mount
3:29:50 #23 Carbon Pilot Stick
3:32:05 #24 Spark Plug Wiring Paint
3:34:42 #25 Water Cooling System
3:41:25 #26 Aluminum Fuel Tank
3:55:29 #27 Fuel Tank Mount
4:00:23 #28 Overflow Bottle Mount
4:08:11 #29 Throttle Control System
4:21:31 #30 Choke Control System
4:35:09 #31 Cockpit Tachometer Mount
4:44:11 #32 Carburetor Intake Reinforcement Plate
4:52:03 #33 Pilot Safety Harness
5:03:44 #34 Fuel Delivery System
5:08:15 #37 Fuel Line Install
5:13:06 #38 Engine Primer System
5:18:29 #39 Beltdrive Engine Pulley
5:21:55 #40 Windscreen+ Cabin Body Panels
5:27:28 #41 Two Year Build Overview
5:31:54 #42 Hood Bodywork+ Head Lights
5:40:47 #43 Freewheel Beltdrive Pulley
5:56:31 #44 Central Gearbox
0:00:00 Intro
0:03:53 #46 Tail Rotor Transmission Shaft
0:23:36 #47 Main Rotor Transmission
0:38:28 #48 Weight and Balance
0:44:41 #49 Tail Rotor Gearbox
1:05:26 #50 Tail Rotor Gearbox Install
1:15:31 #51 Complete Tear Down
1:25:57 #52 Frame Structure Reunion
1:33:54 #53 Rotax Engine Install
1:40:22 #54 Engine Exhaust Install
1:44:01 #55 Main Rotor Mast Update + Reinstall
1:55:04 #56 Flight Controls Update
2:20:42 #57 Pilot Seat Update
2:28:44 #58 Main Gearbox Update + Reinstall
2:51:11 #59 Fuel Tank Update
3:03:30 #60 Main Rotor Blades
0:00:00 Intro
0:00:00 Intro
cancer49 aime ce message
» moteur expérimental à cylindre mobile
» Test : Quelle est la précision réelle des pinces ER chinoises "5 microns"
» Pilote d'helicoptere dans le BTP (couler une dalle béton de 200 m2 seul)
» Fabrication d'une pale (composite) d'hélicoptère chez Airbus Helicopters
» Retex 1 an de CNC (Mekanika EVO taille M)
