Matrix N° 39 & 46
Passion-Usinages :: Documentation :: Machines Outils: Manuels & Docs (Machinery Manuals & Brochures) :: Affuteuses - Rectifieuses - Tourets
Matrix N° 39 & 46
Matrix N° 39 & 46 manuel
Matrix N° 39 & 46 manuel repaginé merci a PMX
Specification Matrix N° 46:
Max Length Between Centres 1066mm
Max Length with Chuck 984mm
Max Diameter of Workpiece 254mm
Max Length Ground at one Setting A 1041mm
Max Lead Recommended 304mm
Min Pitch Recommended 60 TPI
Max Helix Adjustment 45Degree
Max Capacity of Collet 38mm
Max Including Taper per Foot 25.4mm
Variable 0-5m/m
Workhead Speed Range 21-39 RPM
Return Speed Variable to 60 RPM
H.P. of Wheelhead Motor 3.5 / 1.75
H.P. of Workhead Motor 0.75
Max Weight of Work Recommended 100 lb
Head and Tail Stock Centres No 4 Morse
Standard Wheel Diameter 406mm
Variable 0-5m/m
