SOMAB POLYMAB SP 900
Passion-Usinages :: Documentation :: Machines Outils: Manuels & Docs (Machinery Manuals & Brochures) :: CNC :: Tours CN
SOMAB POLYMAB SP 900 plaquette
CN NUM 1060 T
Ø ADMISSIBLE AU DESSUS DU BANC mm 500
Ø ADMISSIBLE DE PASSAGE DANS LE ROMPU mm 600
OPTION SP ( banc incliné) OUI
DIMENSION DU BANC INCLINE mm 1470 X 385
COURSE VERTICALE mm X 600
COURSE TRANSVERSALE mm Y 400
COURSE LONGITUDINALE mm Z 900
AXE C OUI
Ø DU MANDRIN mm 250
Ø ALESAGE DE BROCHE mm 72
VITESSE DE BROCHE (trs/min) 60 - 3000
NEZ DE BROCHE A1 8" ISO
PUISSANCE DU MOTEUR DE BROCHE Kw 26 - 36
TETE PORTE OUTILS ( axe B) OUI
NEZ BROCHE OUTILS TOURNANTS ET FIXES ISO 40
VITESSE DE BROCHE (trs/min) 4000
INDEXAGE DE LA TETE TOUS LES 2.5 °
VITESSE MOTEUR DE FRAISAGE (trs/min) 12.000
PUISSANCE MOTEUR DE FRAISAGE Kw 9 - 12.5
CHANGEUR MAGASIN OUTILS 36
CONTRE POINTE HYDRAULIQUE OUI
VISOPORT OUI
TENSION TRI 380 V
ANNEE 1995
POIDS 12000 Kg
CN NUM 1060 T
AXE C OUI
Ø DU MANDRIN mm 250
VISOPORT OUI
TENSION TRI 380 V
ANNEE 1995
POIDS 12000 Kg
» SOMAB Transmab 200 (+250)
» SOMAB UNIMAB 300, 400, 500
» SOMAB 350 NUM 1060
» transfert programme tour somab
