Zispo fu-1a
Re: Zispo fu-1a
i had a serios amount of stres getting it of the trailer
paukerock- Membre confirmé
Re: Zispo fu-1a
Hello
The less stressing solution is to use a trailer (or pieces of 100 mm diameter steel pipe) slightly smaller than the machine bottom.
And when the machine is in place in the workshop, to screw 4 threaded feet in the base of the machine.
By acting on the threads, you can slightly up the machine. Thus, it is possible to remove the trailler or the pipes.
After removing the trailer or rolls, you can down the machine by acting on the screws and you can adjust the horizontality of the table.
No risk, no stress !
paukerock aime ce message
