Build a steam car
Build a steam car
Message  galglg le Mer 27 Nov 2013, 12:12
This is a complex and lengthy process, the initial idea of ??the steam engine mounted on the bonnet, the axial drive in the middle of the planetary gear set. Boiler rear. Steam with hose connection, the exhaust gas is discharged through the hose from the rear of the vehicle.
Use new rubber tires to solve the steering wheel skid, wheel side drive.
Engine compartment re-do the paint treatment rust. Making a separate front wheel suspension. Axle mounted copper sleeve.
galglg
Re: Build a steam car
Message  lepat le Mer 27 Nov 2013, 21:47
i'm very impressive of the quality of your job
i will follow this topic
see you
lepat
Message  Bilbil le Mer 27 Nov 2013, 22:08
galglg goodnight,
a small presentation helps.
but beinvenue in the forum and good luck for the future.
http://passion-usinages.forumgratuit.org/f20-presentation-des-membres
good evening.
bonsoir galglg,
une petite présentation passe mieux.
mais beinvenue dans le forum et bonne continuation pour la suite.
bonne soirée. rabbit
Message  Lil le Jeu 28 Nov 2013, 06:34
Hi galglg
Welcome aboard.
It's really nice to share your vapor productions with the forum.
Have a nice day.
Administratrice
Administratrice
Message  galglg le Mar 14 Jan 2014, 03:03
galglg
Message  Lil le Mar 14 Jan 2014, 06:29
Hello Galglg
I guess this is a very interesting subject for model makers, but I know nothing in vapor modeling Embarassed
Congratulations  rabbit
Administratrice
Administratrice
