Build a steam car
Build a steam car
This is a complex and lengthy process, the initial idea of ??the steam engine mounted on the bonnet, the axial drive in the middle of the planetary gear set. Boiler rear. Steam with hose connection, the exhaust gas is discharged through the hose from the rear of the vehicle.
Use new rubber tires to solve the steering wheel skid, wheel side drive.
Engine compartment re-do the paint treatment rust. Making a separate front wheel suspension. Axle mounted copper sleeve.
galglg- Membre confirmé
Re: Build a steam car
i'm very impressive of the quality of your job
i will follow this topic
see you
lepat- Nouveau
galglg goodnight,
a small presentation helps.
but beinvenue in the forum and good luck for the future.
https://passion-usinages.forumgratuit.org/f20-presentation-des-membres
good evening.
bonsoir galglg,
une petite présentation passe mieux.
mais beinvenue dans le forum et bonne continuation pour la suite.
good evening.
bonsoir galglg,
Bilbil- Modérateur
Hi galglg
Welcome aboard.
It's really nice to share your vapor productions with the forum.
Have a nice day.
Welcome aboard.
Have a nice day.
Hello Galglg
I guess this is a very interesting subject for model makers, but I know nothing in vapor modeling
Congratulations
Congratulations
» Live Steam 130 LOCOMOTIVE OO HO scale LIVE STEAM Conversion
» essais flash-steam et semi flash-steam
» steam tractor
» V4 Steam Engine
» Steam Logging
» steam tractor
» V4 Steam Engine
» Steam Logging
