WENZEL TRIDIMENSIONNELLE LH 2015
Message  Enfield le Dim 17 Juin 2012, 10:47
Caractéristiques:
SURFACE UTILE DU MARBRE mm: 2050 X 4500
EPAISSEUR DU MARBRE mm: 600
CAPACITE DE MESURE X Y Z mm: X 2000 Y 3500 Z 1500
POIDS MAXI ADMIS SUR LE MARBRE: 6000 KG
SYSTEME DE MESURE: REGLES INCREMENTALES
RESOLUTION / REPRODUCTIVITE mm: 0.0005 / 0.0025
TEMPERATURE CONSEILLE: 20°
ALIMENTATION AIR COMPRIME: 6 Bars / 150 Nl/mn
TENSION 115 / 220 V - 50 / 60 Hz
PUISSANCE ABSORBEE: 1500 W
POIDS: 27.000 KG
ENCOMBREMENT: L 5100 x l 3200 x H 5100
